ASA EtherChannel to a switch stack
Rodrigo Gurriti
Level 3
Level 3
Here is a reference from the documentation:
http://www.cisco.com/c/en/us/td/docs/security/asa/asa94/configuration/general/asa-general-cli/interface-echannel.html#pgfId-1886893
The ASA does not support connecting an EtherChannel to a switch stack. If the ASA EtherChannel is connected cross stack, and if the Master switch is powered down, then the EtherChannel connected to the remaining switch will not come up.
1st - Why do they behave like that?
2nd - If I have a active/standby scenario, where I have a primary with a 2 interface channel to the master and the standby has a 2 interface channel to a single slave switch. Would it work this way?
Rod
Carlos Amador
Rod,
As it is not supported we won't have much info (pretty much behaves like that by design). Best guess reading around some scenarios, could be because the ASA brings the Etherchannel up using the master switch ID, so if it goes down then the port goes down.
I found that you can try configuring static etherchannel (mode on) and see if it works, still will be unsupported or use 'stack-mac persistent timer 0'
Check it over here:
https://tools.cisco.com/bugsearch/bug/CSCtw63096/?reffering_site=dumpcr
Regards.
Carlos Amador
Rod,
Check it over here:
Regards.
Thank you Carlos,
I guess a need to set up a lab and verify which one is better, mode on or the stack-mac persistent command.
I guess the stack-mac can cause a few problems if someone is trying to troubleshoot this network later on if they have to replace a switch.
I also found this document that really points to mode on, if the problem is really the system-id from the master
https://supportforums.cisco.com/discussion/11618031/stack-mac-persistent-timer-lacp-port-channels-c3750
It worked mode on.
Reloaded the master and the ASA primary/active lost his 2 interfaces and the secondary/standby took over and I had only 1 packet loss.
Did not try the command "stack-mac persistent timer 0" because I was running out of time!
Thank you
Rod
