07-19-2008 12:56 AM - edited 03-11-2019 06:16 AM
I have a point to point connection to the ISP thru cat6, n terminating on the ASA firewall outside interface. ISP is using private IPs on this link. Theye have alloted us 8 block public ip addresses for DMZ n etc..
I want to enable ipsec/ssl vpn on ASA. To achieve this I tried in different ways.
A) Done static translation to inside interface to outside public IP address. This is not working. Inside IP is 10.10.1.1
static (inside,outside) 202.x.x.244 10.10.1.1 netmask 255.255.255.255
B) I have also tried using the arp static command to bind one public IP to the mac address of outside interface. But it didn't work.
Does anyone has any idea how to do this.
07-19-2008 01:22 AM
You must use public ip on outside interface.
07-19-2008 07:16 AM
or ask your provider to do a static nat for you.
for example you have 202.x.x.240/29
network address 202.x.x.240
brodcast 202.x.x.248
ask provider to nat 202.x.x.240 into the private IP of the outside interface of the ASA.
