ASA5505 dual ISP both with PPPOE setroute on both interfaces
davidbuit
I would like to setup an ASA5505 with dual ISP connections.  Both of the internet connections authentication and obtain their IP address and default route using PPPOE setroute. When I have configure dual ISP support on ASA's in the past I would normally use the sla monitoring and track commands as below but because the default routes in this case are set using PPPOE it isn't possible to manually define the default routes as with the example below.
As this is a 5505 I will use the backup interface command on the primary outside interface. Is this all that is required?  Is there a way of configuring an SLA monitor to track using PPPOE setroute on both interfaces?
Normal static IP address example
route outside 0.0.0.0 0.0.0.0 10.200.159.1 1 track 1
route backup 0.0.0.0 0.0.0.0 10.250.250.1 254
sla monitor 123
type echo protocol ipIcmpEcho 10.0.0.1 interface outside
num-packets 3
frequency 10
sla monitor schedule 123 life forever start-time now
track 1 rtr 123 reachability
Any assistance would be much appreciated.
Nagaraja Thanthry
If you do not have license restriction (Security Plus License), then you can
use the track option under PPPoE as well.
interface VLAN 2
ip address PPPoE setroute
pppoe client route track "track id"
interface VLAN 3
pppoe client route distance 254
Hope this helps.
NT
Nagaraja Thanthry
interface VLAN 2
interface VLAN 3
Hope this helps.
NT
Thank you, that is what I was looking for.
