Cisco Pix 515E PDM or Web Gui
parisvcisco
I don't have much experience with firewalls so I'm trying to find out how I can manage a Pix 515e via a Gui or a web front end, whilst I try and get my head around the cli.
I've seen posts about a PIX pdm but I cannot find where to download it. I'd also need some details on how to install/enable it.
some details from sh ver:
Cisco PIX Security Appliance Software Version 8.0(4)
Compiled on Thu 07-Aug-08 19:42 by builders
System image file is "flash:/image.bin"
Config file at boot was "startup-config"
pix01 up 286 days 0 hours
failover cluster up 1 year 223 days
Hardware:   PIX-515E, 128 MB RAM, CPU Pentium II 433 MHz
Flash E28F128J3 @ 0xfff00000, 16MB
BIOS Flash AM29F400B @ 0xfffd8000, 32KB
The PIX was end of life / end of support last year, So there is no support from Cisco on this product any more.
However you can download the PDM here, but you are required to have a valid Cisco support contract to be able to download it.
Please remember to select a correct answer and rate helpful posts
7 Replies 7
ah we actually have a copy of this in our software share along with pix804.bin.
what is the procedure to install this?
You can find installation instruction at the following URL:
http://www.cisco.com/en/US/docs/security/pix/pix63/pdm30/installation/guide/pdm30CH3.html#wp1002608
great thanks for your help.
Any time, Thank you for the rating smiley
1 issue is that these instructions seem to be for a new device as it says run setup, which I don't want to do.
once I do this:
copy tftp://Your_TFTP_Server_IP_Address/Your_pdmfile_name flash:pdm
what would be the next step?
Try the following (where the management IP/subnet is the IP or subnet that is allowed to manage the firewall and "inside" is the interface name management traffic is entering the firewall):
http server enable
http <management IP/subet> inside
aaa authentication http console LOCAL
username cisco password cisco
Please select a correct answer and rate helpful posts
