FW-4-TCP_OoO_SEG: TCP reassembly queue overflow - session
marc.groenen
After upgrading a Cisco 892 to IOS c890-universalk9-mz.151-4.M3.bin from c890-universalk9-mz.124-22.YB.bin(reason was tracebacks) we have noticed the following message's in the logging:
%FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:1628726886 1492 bytes is out-of-order; expected seq:1628698086. Reason: TCP reassembly queue overflow - session x:42024 to x:80 on zone-pair ccp-zp-in-out class ccp-protocol-http
%FW-4-TCP_OoO_SEG: Deleting session as expected TCP segment with seq:972828144 has not arrived even after 25 seconds - session x:57229 to x:80 on zone-pair ccp-zp-in-out class ccp-protocol-http
After some research we tuned the timers of the tcp reassembly
ip inspect max-incomplete high 8000
ip inspect max-incomplete low 7900
ip inspect one-minute high 8000
ip inspect one-minute low 7900
ip inspect udp idle-time 360
ip inspect dns-timeout 10
ip inspect tcp idle-time 7200
ip inspect tcp finwait-time 10
ip inspect tcp max-incomplete host 1000 block-time 0
ip inspect tcp reassembly queue length 1024
ip inspect tcp reassembly timeout 60
ip inspect tcp reassembly memory limit 256000
However the message's still appear and i cant explain why the sh ip inspect statistics is empty
#sh ip inspect statistics
Interfaces configured for inspection 0
Session creations since subsystem startup or last reset 0
Current session counts (estab/half-open/terminating) [0:0:0]
Maxever session counts (estab/half-open/terminating) [0:0:0]
Last session created never
Last statistic reset never
Last session creation rate 0
Maxever session creation rate 0
Last half-open session total 0
TCP reassembly statistics
  received 0 packets out-of-order; dropped 0
  peak memory usage 0 KB; current usage: 0 KB
  peak queue length 0
The message's did not occur while running c890-universalk9-mz.124-22.YB
mirober2
Hi Marc,
The 'ip inspect' commands and statistics are used for CBAC rather than zone-based firewall. For ZBF, you can tune the reassembly settings with a parameter-map:
parameter-map type ooo global
You can view the queue statistics with the 'show policy-firewall stats all' or 'show policy-map type inspect zone-pair' commands.
Ultimately though, you should investigate why the router is receiving so many out-of-order packets and resolve that issue upstream.
-Mike
mirober2
Hi Marc,
-Mike
Thank you for youre reply.
I have also tried the paramet-map ooo settings but these also didnt resolve the issue.
Im not getting any complaints from the clients at the site.
I will go onsite next week and will do some testing/sniffing.
UPDATE:
After tweaking the buffers and time outs the TCP reassembly queu overflow message does not occur anymore.
Now only the following message occurs:
%FW-4-TCP_OoO_SEG: Deleting session as expected TCP segment with seq:4121294117 has not arrived even after 900 seconds - session xxxxx to xxxxxxxxx on zone-pair ccp-zp-in-out class ccp-protocol-http.
During an onsite test the test client also generated this message however the client did not notice this and his download and the speed where OK.
Thread can be closed
