(NAT configuration) Transparent mode
bhalbautista
Hi Guys,
I'm having problem with the translation of my private networks outside and I'm little bit confused where should I put the NAT. Btw, here's the scenario. I have Cisco 1841 router running DHCP services then I have 1 Cisco 2901 which is a WAN side, in between of these I put ASA Firewall as a transparent mode. Anyhow please see my configuration below. Hope someone could help me on this. Thanks
Cisco 1841
ip dhcp pool 1.1.1.0/24
network 1.1.1.0 255.255.255.0
default-router 1.1.1.254
ip dhcp excluded-address 1.1.1.254
Interface fa0/0
description ##Facing_WAN##
ip address 2.2.2.1 255.255.255.240
duplex auto
speed auto
Interface f0/1
description ##LAN##
ip address 1.1.1.254 255.255.255.0
duplex auto
speed auto
ip route 0.0.0.0 0.0.0.0 2.2.2.3
ASA 5515-x Firewall
firewall transparent
Interface gi0/0
nameif Outside
bridge-group 1
security-level 0
Interface gi0/1
nameif Inside
bridge-group 1
security-level 100
Interface BVI1
ip address 2.2.2.2 255.255.255.240
(access-list was also configured both inside and outside) (permit any any)
Cisco 2901
Interface g0/0
ip address 3.3.3.3 255.255.255.252
duplex auto
speed auto
Interface g0/1
ip address 2.2.2.3 255.255.255.240
duplex auto
speed auto
ip route 0.0.0.0 0.0.0.0 3.3.3.3
(In this case I was able to reach 2.2.2.0/28 with the source of fa0/1 (default-gateway)) So, now I need to know where should I put the NAT and should I also put an ip route from Transparent mode firewall? Please help thanks! Let me know if I missed some configuration here, I highly appreciate their response.
add the following on the asa
route outside 0.0.0.0 0.0.0.0 202.120.1.1
on the router
no ip nat source list 7 pool TEST
ip nat inside source list 7 pool TEST
then let me know
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
11 Replies 11
Julio Carvajal
Hi baltazar,
Check the route on the 2901
Interface g0/0
Why is it pointing to itself??
On the ASA add
route outside 0 0 2.2.2.3
I would do the NAT on the Outside router but that's all up to u
Julio Carvajal
Hi Jc,
Sorry it was actually routed to 0.0.0.0 0.0.0.0 3.3.3.4 this is an example of connection going ISP. I'll try your suggestion thanks jc!
Hey my pleasure,
If you do not have any other question please mark it as answered Baltazar,
Julio Carvajal
Hi JC,
I already put the route from ASA and configured NAT  outside router. It seems that the translation was not able to  translated. Is there any configuration should I add on ASA or in router  instead? Thanks!
Can you share the entire configuration of the devices to double check if everything is as it should?
Julio Carvajal
Hi JC,
Here's the configuration below.
Router 2600
Building configuration...
Current configuration : 1669 bytes
version 12.4
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
no network-clock-participate slot 1
no network-clock-participate wic 0
ip subnet-zero
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.10.20.254
ip dhcp excluded-address 10.10.20.253
ip dhcp pool 10.10.20.0/24
   network 10.10.20.0 255.255.255.0
   default-router 10.10.20.254
   dns-server 8.8.8.8 4.2.2.2
ip name-server 8.8.8.8
ip name-server 4.2.2.2
interface FastEthernet0/0
description ##FACING-WAN##
ip address 202.120.1.2 255.255.255.240
ip nat outside
duplex auto
speed auto
interface FastEthernet0/1
description ##LAN-WORSTATION##
ip address 10.10.20.254 255.255.255.0
ip nat inside
duplex auto
speed auto
ip classless
ip route 0.0.0.0 0.0.0.0 202.120.1.1
no ip http server
ip nat pool TEST 202.120.1.9 202.120.1.10 netmask 255.255.255.240
access-list 7 remark Pool
access-list 7 permit 10.10.20.0 0.0.0.255
access-list 100 permit tcp 10.10.20.0 0.0.0.255 any eq telnet
control-plane
line con 0
line aux 0
line vty 0 4
access-class 100 in
login local
transport input telnet
end
ASA FIREWALL 8.6
sh run
: Saved
ASA Version 8.6(1)2
names
interface GigabitEthernet0/0
nameif Outside
bridge-group 1
security-level 0
interface GigabitEthernet0/1
nameif Inside
bridge-group 1
security-level 100
interface GigabitEthernet0/2
nameif Inside2
bridge-group 1
security-level 100
interface GigabitEthernet0/3
shutdown
no nameif
no security-level
interface GigabitEthernet0/4
shutdown
no nameif
no security-level
interface GigabitEthernet0/5
shutdown
no nameif
no security-level
interface Management0/0
nameif Management
security-level 0
management-only
interface BVI1
ip address 202.120.1.3 255.255.255.240
ftp mode passive
dns domain-lookup Outside
dns domain-lookup Inside
dns server-group DefaultDNS
name-server 8.8.8.8
name-server 4.2.2.2
object-group protocol DM_INLINE_PROTOCOL_1
protocol-object ip
protocol-object icmp
object-group protocol DM_INLINE_PROTOCOL_2
protocol-object ip
access-list Outside_access_in extended permit ip any any log disable
access-list Outside_access_in extended permit icmp any any log disable
access-list Inside_access_in extended permit ip any any log disable
access-list Inside_access_in extended permit icmp any any log disable
pager lines 24
mtu Outside 1500
mtu Inside 1500
mtu Management 1500
mtu Inside2 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
access-group Outside_access_in in interface Outside
access-group Inside_access_in in interface Inside
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
http server enable
http 0.0.0.0 0.0.0.0 Inside
http 0.0.0.0 0.0.0.0 Inside2
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
telnet timeout 5
ssh timeout 5
console timeout 0
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
Cryptochecksum:80858c29d4cb42ba7aa174d09b7191dd
: end
Hello Baltazar,
On wich port is the ASA connected to that router?
I need the port numbers of both the router and ASA
Julio Carvajal
Hi JC,
From router to ASA:
Fa0/0 to Gig0/1 (Inside ASA)
From ASA to WAN:
(Outside) G0/0 to G0/1 (WAN)
on the router
then let me know
Julio Carvajal
Hi JC,
I was able to do the translation. Thank you so much for your help. I just forgot to input the "ip nat inside source" instead.
Yeah,
My pleasure to help
Julio Carvajal
