Port natting when no nat-control is set
alexander.cario
Hello everybody,
is there any clue to NAT PORTS when no nat-control is active "Enable traffic through the firewall without address translation"?
thx in advanced alexx
Sorry I forgott, I uses a FWSM with 4.1(7). thx alexx
Julio Carvajal
Hello Alexander,
Not sure if I understand your question...
Do you want to perform a port-forwarding rule while nat control is not enabled?
If that is the question there is no problem doing that, it's going to work whether you have nat-control on or not.
Any other question..Sure..Just remember to rate all of the helpful answers.
Julip
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
Are sure I have entred many port nattings but they still not working?? should I send the config...... thx alexx
Hello Alexander,
Yes, post the NAT setup and packet-tracer outputs
Julio Carvajal
Okay I will do it tomorrow, thx for help thx alexx
