problem reset-ing ASA 5505
xinteladmin
I'm new to cisco ASA 5505,
I dunno why after i reset my firewall to the  factory default, then restart it... all my default factory setting gone...
below are the command:
config  factory-default
after  it run through the process i type
reload  save-config noconfirm
after  this command, the firewall restart and i type
show run
it  show below setting
ASA  Version 8.2(1)
hostname ciscoasa
enable password 8Ry2YjIyt7RRXU24  encrypted
passwd 2KFQnbNIdI.2KYOU  encrypted
names
interface  Vlan1
no nameif
no  security-level
no ip address
interface Ethernet0/0
shutdown
interface Ethernet0/1
shutdown
interface Ethernet0/2
shutdown
interface Ethernet0/3
shutdown
interface Ethernet0/4
shutdown
interface Ethernet0/5
shutdown
interface Ethernet0/6
shutdown
interface Ethernet0/7
shutdown
ftp mode passive
pager lines 24
icmp  unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout  14400
timeout xlate 3:00:00
timeout  conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc  0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip  0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout  sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout  tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record  DfltAccessPolicy
no snmp-server location
no snmp-server  contact
snmp-server enable traps snmp authentication linkup linkdown  coldstart
crypto ipsec security-association lifetime seconds 28800
crypto  ipsec security-association lifetime kilobytes 4608000
telnet timeout 5
ssh  timeout 5
console timeout 0
threat-detection  basic-threat
threat-detection statistics access-list
no threat-detection  statistics tcp-intercept
prompt hostname  context
Cryptochecksum:00000000000000000000000000000000
:  end
everything  that i restore to default factory setting  gone....
Any  iea what might cause this?? or after i reset the firewall to factory  default there is a command to save the  setting??
7 Replies 7
Jennifer Halim
That is the factory default configuration.
Factory default means removing all your configuration and setting it back to when you just got the device.
August Ritchie
Doing "configure factory-default" should bring you back to the original configuration (including vlan1 ip address and dhcp so  you can manage with ASDM)
So please try this, just do "configure factory-default" then do a show run and see if it is what you are looking for. You don't need to reload as the command should take immediate effect.
If for some reason you are still having the same issue, paste in the commands below to get back to default. Afterwards you can do a "write mem" to save.
First do "config t" from enable
interface Ethernet 0/0
   switchport access vlan 2
   no shutdown
interface Ethernet 0/1
   switchport access vlan 1
   no shutdown
interface Ethernet 0/2
   no shutdown
interface Ethernet 0/3
   no shutdown
interface Ethernet 0/4
   no shutdown
interface Ethernet 0/5
   no shutdown
interface Ethernet 0/6
   no shutdown
interface Ethernet 0/7
   no shutdown
interface vlan2
   nameif outside
   no shutdown
   ip address dhcp setroute
interface vlan1
   nameif inside
   security-level 100
   no shutdown
global (outside) 1 interface
nat (inside) 1 0 0
http server enable
http 192.168.1.0 255.255.255.0 inside
dhcpd address 192.168.1.2-192.168.1.254 inside
dhcpd auto_config outside
dhcpd enable inside
logging asdm informational
Site for reference:
http://www.cisco.com/en/US/docs/security/asa/asa72/configuration/guide/start.html#wp1053752
Message was edited by: August Ritchie - weird formatting
to ritchie
Yes that is the default factory setting that i'm looking for.
and after i
write mem
and reload the ASA5505 i'll get back the following config
SA Version 8.2(1)
hostname ciscoasa
names
interface Vlan1
no nameif
no security-level
no ip address
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
ftp mode passive
pager lines 24
arp timeout 14400
My show running-config and show startup-config is different. How to make the
startup-config = running-config even after i reload the ASA 5505??
Doing a wr mem should save your running-conf to startup-conf.'
My guess is that your configuration register is not default.
What does your "show version" say your config register is?
If it is not 0x1 please use the following command
config-register 0x1
After this, do the default config and wr mem then reload.
Hi ritchie,
here is my show run startup-config
show startup-config
ASA Version 8.2(1)
hostname ciscoasa
names
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ftp mode passive
pager lines 24
mtu outside 1500
mtu inside 1500
arp timeout 14400
nat (inside) 1 0.0.0.0 0.0.0.0
http server enable
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 192.168.1.5-192.168.1.36 inside
dhcpd enable inside
webvpn
Cryptochecksum:98ea9adf0343c4d83971d1bb9c6cf0ab
and here is my running config
show running-config
ASA Version 8.2(1)
hostname ciscoasa
names
interface Vlan1
no nameif
no security-level
no ip address
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
ftp mode passive
pager lines 24
arp timeout 14400
telnet timeout 5
ssh timeout 5
console timeout 0
: end
And here is my show version
show version
Device Manager Version 6.2(1)
Compiled on Tue 05-May-09 22:45 by builders
System image file is "disk0:/asa821-k8.bin"
Config file at boot was "startup-config"
ciscoasa up 1 hour 9 mins
Hardware:   ASA5505, 512 MB RAM, CPU Geode 500 MHz
Internal ATA Compact Flash, 128MB
BIOS Flash Firmware Hub @ 0xffe00000, 1024KB
Encryption hardware device : Cisco ASA-5505 on-board accelerator (revision 0x0)
                             Boot microcode   :  CN1000-MC-BOOT-2.00
                             SSL/IKE microcode:  CNLite-MC-SSLm-PLUS-2.03
                             IPSec microcode  :  CNlite-MC-IPSECm-MAIN-2.04
0: Int: Internal-Data0/0    : address is c84c.75aa.7b2a, irq 11
1: Ext: Ethernet0/0         : address is c84c.75aa.7b22, irq 255
2: Ext: Ethernet0/1         : address is c84c.75aa.7b23, irq 255
3: Ext: Ethernet0/2         : address is c84c.75aa.7b24, irq 255
4: Ext: Ethernet0/3         : address is c84c.75aa.7b25, irq 255
5: Ext: Ethernet0/4         : address is c84c.75aa.7b26, irq 255
6: Ext: Ethernet0/5         : address is c84c.75aa.7b27, irq 255
8: Ext: Ethernet0/7         : address is c84c.75aa.7b29, irq 255
9: Int: Internal-Data0/1    : address is 0000.0003.0002, irq 255
10: Int: Not used            : irq 255
11: Int: Not used            : irq 255
Licensed features for this platform:
Maximum Physical Interfaces  : 8
VLANs                        : 3, DMZ Restricted
Inside Hosts                 : 10
Failover                     : Disabled
VPN-DES                      : Enabled
VPN-3DES-AES                 : Enabled
SSL VPN Peers                : 2
Total VPN Peers              : 10
Dual ISPs                    : Disabled
VLAN Trunk Ports             : 0
Shared License               : Disabled
AnyConnect for Mobile        : Disabled
AnyConnect for Linksys phone : Disabled
AnyConnect Essentials        : Disabled
Advanced Endpoint Assessment : Disabled
UC Phone Proxy Sessions      : 2
Total UC Proxy Sessions      : 2
This platform has a Base license.
Serial Number: JMX142441Q5
Running Activation Key: 0x611fec40 0x602759d6 0x44d17550 0xaff8a8f8 0xcd0110b7
Configuration register is 0x41
Configuration has not been modified since last system restart.
Your config register is set wrong according to your show version we see here:
Please run the command
config-register 0x1
Then do the config factory-def and wr mem. Reload
Thanx richie.
problem solved...
