Bug Report on CSR1000v
RenatoOliveira
SUMMARY
Incorrect device configuration when using OpenConfig OSPF payload for NETCONF
Demonstration : https://youtu.be/7npu5QNF5No
ISSUE TYPE
  • BUG REPORT
IOS-XE VERSION
Cisco IOS XE Software, Version 16.09.03
Cisco IOS Software [Fuji], Virtual XE Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 16.9.3, RELEASE SOFTWARE (fc2)
STEPS TO REPRODUCE
from ncclient import manager
import xmltodict
import xml.dom.minidom
xml_string = '''
<config>
    <network-instances xmlns="http://openconfig.net/yang/network-instance">
        <network-instance>
            <name>default</name>
            <protocols>
                <protocol>
                    <identifier xmlns:oc-pol-types="http://openconfig.net/yang/policy-types">oc-pol-types:OSPF</identifier>
                    <name>1</name>
                    <config>
                        <name>1</name>
                    </config>
                </protocol>
            </protocols>
        </network-instance>
    </network-instances>
</config>
m = manager.connect(
    host='ios-xe-mgmt.cisco.com',
    port=10000,
    username='developer',
    password='C1sco12345',
    hostkey_verify=False
netconf_reply = m.edit_config(xml_string, target = 'running')
EXPECTED RESULTS
OSPF process 1 configured.
ACTUAL RESULTS
BGP for ASN 1 configured.
Alexander Stevenson
Hello Renato,
I found a bug from this exact software version release related to NETCONF.
URL:
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvp13260
Symptom:
netconf-yang command can not use after 16.9.3 upgrade
Workaround:
Change redundancy mode to none and reboot
I hope this helps!
Best Regards,
                    Alex Stevenson
