Meraki always-on sandbox API calls to create objects
juan-ruiz
Hi Team,
I'm using the Meraki always-on Sandbox to test ansible modules to create organizations and other network related objects and query information and everything works really well but my problem is when I query from ansible I can see the resources that I created and access the data points such as org-id etc but when I login into the always-on dashboard those resources are not present or visible.
My question is what dashboard do I need to login to so I can see those resources I created using the API with Ansible?
Here is the link for the Meraky always-on sandbox
https://devnetsandbox.cisco.com/DevNet/catalog/meraki-always-on_meraki-always-on
@juan-ruiz you might want to check that is possible on the sandbox. Most of the always on sandbox only accept GET requests and are reqs only via the API/UI. For other types of request, you might need to use the reservation based sandbox which allows full admin access. It should say in the sandbox instructions what you can do with the always on version.
Hope that helps.
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
