Converting PYATS output to list format
rasmus.elmholt
Level 7
Level 7
Hi Everyone,
I am trying to use PYATS to pull some LLDP neighbor information from some switches.
The format I get out of it is nested JSON, but I want to have the information in a easy to iterate over list format.
As you can see above the LLDP information is neste. The best for me would be to have the data in a list contaning the interface neighbors and id.
How do I convert this format to something easy to iterate over like the CDP output from PYATS?
Marcel Zehnder
You may use this function:
def genieLldp_2_listOfDicts(lldpdict):
    result = list()
    for localint, remote in lldpdict.get("interfaces").items():
        for remoteint, remotedetails in remote.get("port_id").items():
            for neighbor in remotedetails.get("neighbors").keys():
                result.append({
                    "local_int": localint,
                    "remote_int": remoteint,
                    "neighbor": neighbor.strip()
    return result
Complete example:
import json
    result = list()
                result.append({
    return result
lldp = {
  "interfaces": {
    "GigabitEthernet2": {
      "port_id": {
        "Gi0/3": {
          "neighbors": {
            "IOSvL2.lab          ": {
              "capabilities": [
                "R"
              "hold_time": 120
    "GigabitEthernet3": {
      "port_id": {
        "Gi0/2": {
          "neighbors": {
            "IOSv.lab            ": {
              "capabilities": [
                "R"
              "hold_time": 120
    "GigabitEthernet4": {
      "port_id": {
        "Gi0/1": {
          "neighbors": {
            "IOSv2.lab           ": {
              "capabilities": [
                "R"
              "hold_time": 120
  "total_entries": 3
print(json.dumps(genieLldp_2_listOfDicts(lldp), indent=1))
Result:
  "local_int": "GigabitEthernet2",
  "remote_int": "Gi0/3",
  "neighbor": "IOSvL2.lab"
  "local_int": "GigabitEthernet3",
  "remote_int": "Gi0/2",
  "neighbor": "IOSv.lab"
  "local_int": "GigabitEthernet4",
  "remote_int": "Gi0/1",
  "neighbor": "IOSv2.lab"
Marcel
Marcel Zehnder
    result = list()
                result.append({
    return result
Complete example:
import json
    result = list()
                result.append({
    return result
lldp = {
  "interfaces": {
      "port_id": {
        "Gi0/3": {
          "neighbors": {
            "IOSvL2.lab          ": {
              "capabilities": [
                "R"
              "hold_time": 120
      "port_id": {
        "Gi0/2": {
          "neighbors": {
            "IOSv.lab            ": {
              "capabilities": [
                "R"
              "hold_time": 120
      "port_id": {
        "Gi0/1": {
          "neighbors": {
            "IOSv2.lab           ": {
              "capabilities": [
                "R"
              "hold_time": 120
  "total_entries": 3
Result:
Marcel
Tagir Temirgaliyev
use ansible gather_facts: yes
as here :
https://raw.githubusercontent.com/NWMichl/network-automation/master/fix_ifdesc.yml
Fix Your Interface Description with Ansible and CDP/LLDP – NWMichl Blog
- name: Set Interface description based on CDP/LLDP discovery
  hosts: all
  gather_facts: yes
  connection: network_cli
  tasks:
  - name: Set IOS Interface Description
    ios_config:
      lines:
        - description Connected to {{ item.value[0].host }} via its {{ item.value[0].port }}
      parents: interface {{ item.key }}
      save_when: changed
    with_dict: "{{ansible_facts.net_neighbors }}"
    when: ansible_network_os == 'ios'
  - name: Set NXOS Interface Description
    nxos_config:
      lines:
      save_when: changed
    when: ansible_network_os == 'nxos'
and you will have dictionary :   ansible_facts.net_neighbors
