Python netmiko error
minhtetsan192
Visitor
Dear Sir,
I'm a beginner at Network automation. Please kindly help with my issue.
from netmiko import ConnectHandler
MHS_SWITCHES = {
'device_type' : 'cisco_ios',
'ip': '192.168.32.100',
'username' : 'admin',
'password' : 'cisco',
'secret': 'secret'
net_connect = ConnectHandler(**MHS_SWITCHES)
onput = net_connect.send_command('show ip int brief')
print(onput)
This is my simple python file with netmiko. But, if I run this script, I always get an error. Please check below.
root@davidsam-virtual-machine:/etc/python3.10# python3 netmiko.py
Traceback (most recent call last):
File "/etc/python3.10/netmiko.py", line 1, in <module>
ImportError: cannot import name 'ConnectHandler' from partially initialized module 'netmiko' (most likely due to a circular import) (/etc/python3.10/netmiko.py)
pip list | grep netmiko
netmiko 4.1.0
python3 --version
Python 3.10.4
I need your support. Thanks!!!
2 Accepted Solutions
  It seems to me some conflict. You created a file called netmiko.py, rith?   Try to use a different name.  As per the logs, it seems that it is trying use your file as part of the Netmiko library and is failing.
#Mat
Level 6
Level 6
Hello minhtetsan192 ! Change your app netmiko.py to, for example, main.py and try again.
MO.
7 Replies 7
Thank you so much, sir. Now my issue was soloved.
Best Warm Regards,
Min Htet San
Thanks, I just made this exact error as well!
I am having same problem. My file name is Test. By the way, I'm using VS Code
Hello @Badshah,
You will need to install the Netmiko python module. I would also suggest posting this as a separate thread as the issue is not the same as the one described above.
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
#Mat
Level 6
Level 6
MO.
Thank you so much, sir. Now my issue was solved.
Best Warm Regards,
Min Htet San
