1747
Script to "tell" the phone to call
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
03-12-2020 05:36 AM - edited 03-12-2020 07:15 AM
I've been trying to make a script in JS to make a phone call from pc using the cisco phone, found the script below in php, wich works and i've been trying to make it work in js with no sucess so far.
php script: https://github.com/samturner3/Cisco-IP-Phone-Dial-from-Web/blob/master/dialPush.php
Any help is appreciated,
thank you.
var net = require('net'); var number = "***"; var host = "**.*.***.***"; var data = '<CiscohostPhoneExecute><ExecuteItem Priority="0" URL="Dial:' + number + '"/></CiscohostPhoneExecute>'; var path = "/CGI/Execute"; var res = phonecall(host, data); function phonecall(host, data, uid = "***", pwd = "***") { var aux = uid + ":" + pwd; var auth = Buffer.from(aux).toString('base64'); console.log("encoded: " + auth); var xml = "XML=" + encodeURI(data); var http_request = "POST " + path + " HTTP/1.0\r\n"; http_request += "Host: " + host + "\r\n"; http_request += "Authorization: Basic " + auth + "\r\n"; http_request += "Connection: close\r\n"; http_request += "Content-Type: application/x-www-form-urlencoded\r\n"; http_request += "Content-Length: " + xml.length + "\r\n"; console.log(http_request) //var client = net.connect(80,host, function(){ var client = net.createConnection(80, host, function () { console.log("ABC"); //client.write(xml); client.end(xml); console.log("END") }); } module.exports.phonecall = phonecall;
I've also tryed to use WebSockets.
Labels:
- Labels:
Other Networking Topics
0 Replies 0
