Design clarification for ISE PAN/MNT Personas
yasirirfan
Level 4
Level 4
Hi All
I have a query related to ISE deployment for 10 K users.
We have a set of dedicated ISE appliances ( 3595) for PAN/MNT personas.
We are planning to have active PAN/ secondary MNT personas  in distributed model  and other appliance as Secondary PAN/ active MNT personas.
This is a known design and often it is observed both sets are in same data centre. However I have a query can we have one set in Data Center 1 and other in Data Centre 2. Data Center 1 and Data Centre are connected with 1 gig link as primary and 20 MBPS MPLS link.
PSN will connect to these PAN/MNT personas  for both wired and wireless network.
I have attached the propose topolgy , can any one share their views is this a correct way of deployment?
Cheers
Yasir
Craig Hyps
Level 10
Level 10
Certainly, you can split the nodes across DCs, but I would also recommend collocating the Primary for both Admin and MnT in one DC and Secondary at the other (i.e. not split Primary/Secondary).  The diagram looks like it was based on one I created a while back, but current diagram (from BRKSEC-3699) reflects my recommendation.
Craig
Craig Hyps
Level 10
Level 10
Craig
Timothy Abbott
Yasir,
Your design proposal is a supported configuration.  Just be sure to observe latency requirements.  We have tons of resources you can use here in the community you can reference.
-Tim
yasirirfan
Level 4
Level 4
Hi chyps thanks for your valuable feedback. Really appreciate your inputs. I will look into that.
Hi tiabbott nice point about the latency. Well we are in the specified latency limits.
Yasir
