Device sensors and profiling probes
dtjacob
I am the using the following device sensor configuration on the catalyst 3850 and 4500 models:
device-sensor filter-list sip list sip_profiling
tlv name device-name
tlv name device-version
tlv name device-vendor
device-sensor filter-list dhcp list dhcp_profiling
option name host-name
option name default-ip-ttl
option name requested-address
option name parameter-request-list
option name class-identifier
option name client-identifier
device-sensor filter-list lldp list lldp_profiling
tlv name system-name
tlv name system-description
device-sensor filter-list cdp list cdp_profiling
tlv name address-type
tlv name capabilities-type
tlv name platform-type
device-sensor filter-spec sip include list sip_profiling
device-sensor filter-spec dhcp include list dhcp_profiling
device-sensor filter-spec lldp include list lldp_profiling
device-sensor filter-spec cdp include list cdp_profiling
device-sensor accounting
device-sensor notify all-changes
I am trying to profile a Cisco IP Phone 7841.  The switchport is configured with a voice vlan and cdp is enabled.  ISE is configured with a wired MAB policy that uses an endpoint groups for voip phones AND cisco-ip-phone profiling to assign the ip phone to a voice vlan. When I had the following probes enabled on the PSNs - radius, dhcp, http, snmpquery, and snmptrap - the ip phone was correctly profiled and immediately assigned to the voice vlan.  When I configured the PSNs to only use radius for profiling, it took the phone a very long time to correctly profile and sometimes not they didn't authorize at all.  I figured out the issue was profiling.  My question is....even though device sensors are configured on the switch and passed to ISE via Radius, do I need to have the DHCP and Radius probes enabled to properly profile an IP phone?
hslai
ISE RADIUS probe should be able to collect the CDP attributes for the phone, without enabling other probes. I would suggest to temporarily enable profiling DEBUG and check profiler.log or engage Cisco TAC to troubleshoot.
hslai
Please make sure to turn on Radius accounting. CDP information is sent via Radius accounting packets.
Cory Peterson
Level 5
Level 5
I know I am a bit late to this one but also keep in mind that Device Sensor / Radius Accounting ONLY happens after a successful authentication. So if the phone is failing Auth for whatever reason then ISE will never receive any of the information from the switch through RADIUS.
This boils down to the way radius works and will not send account packets for any device that is failing Authorizations.
There was also a bug reported on this but it was closed stating that  it is only a documentation bug and this is working as intended.  Bug ID: CSCux48616
It would be nice to gather this information even on a failed Auth so that ISE can correctly profile the device and then send a COA to the device to apply the correct policy.
One work around would be to do an access accept at the bottom of the MAB policy with a very restrictive dACL or even a deny any any.
