Integration questions: Pulse Secure Odyssey Access Client and Cisco ISE
dgaikwad
Level 5
Level 5
Hi Experts,
I am looking for some details over the integration and working on Pulse Secure Client with ISE?
Could anyone direct me to some more information and documentation of these two?
howon
I am not aware of such documents, but Pulse Secure Odyssey Access Client is a 802.1X supplicant and ISE is RADIUS server. They interact via EAP. Make sure you are using EAP types that is supported by both sides and should work.
howon
So, if this client is being used, then there is no chance of running posture checks using ISE?
Can it be said that this is equivalent to NAM?
