02-06-2017 01:15 PM
Is there a more recent version of the document below? This version maps ISE 1.2 to PCI 2.0.
Thanks!
Warren
Solved! Go to Solution.
02-09-2017 07:11 AM
Hi Warren,
I did get a response this morning from our folks with respect to PCI compliance.
The long and short is: everything is here: cisco.com/go/pci
Thank you,
02-09-2017 07:11 AM
Hi Warren,
Thank you,
11-30-2017 12:41 PM
so nothing really that mentions ISE and where it fits in, so not very helpful.
11-30-2017 12:56 PM
I have asked our product manager for PCI surasky to look into this
11-30-2017 01:14 PM
much appreciated, as I have a customer needing this info.
Thanks'
Jeff
12-01-2017 01:03 PM
Our expert is travelling, should have something in next few days
12-01-2017 01:07 PM
ok thanks, what i need for the customer run book I am putting together, is all aspects of ISE per each check of PCI compliance.
12-04-2017 03:49 AM
Hi Jeffrey,
ISE takes part in PCI compliance by making the segmentation process much easier. This can be done via TrustSec (restaurants https://www.cisco.com/c/dam/en/us/solutions/collateral/enterprise-networks/trustsec/trustsec_pci_validation.pdf) or by using ISE for auto VLAN assignment based on many different cretirieas: AD group, device profile and more. in ISE 2.4 we are going to allow customers to disable TLS 1.0/1.1 as part of the new PCI requirements.
please let me know if you need more info.
Tal
