TACACS using Guest Identity store
melvillec
Hi All,
Our customer requires tacacs users to have an expiry date & time and for different ISE admins to create different types of tacacs users.
For this I have created sponsored guests users using the guest type Contractor group.
Now, if I use the network access name as that of the sponsored guest created, the tacacs rule works as required.
However, If I use the Identity group name Contractor, authorisation fails and it hits the default deny access shell profile.
Any idea how to get it working using the Identity Group name
Attached authorisation SS of both conditions.
PASSED LOG
Overview
Request TypeAuthorization
StatusPass
Session KeyISE2673/356880508/180
Message TextDevice-Administration: Command Authorization succeeded
Usernamenetadmin@gmail.com
Authorization PolicyNew Policy Set 1 >> NetAdmin
Shell Profile
Matched Command SetPermitAll
Command From Deviceenable
Authorization Details
Generated Time2019-09-03 16:16:38.118 +5:30
Logged Time2019-09-03 16:16:38.118
Epoch Time (sec)1567507598
ISE NodeISE2673
Failure Reason
Resolution
Root Cause
Network Device NameCOE_3850_2
Network Device IP192.168.40.8
Network Device GroupsIPSEC#Is IPSEC Device#No,Location#All Locations,Device Type#All Device Types
Device TypeDevice Type#All Device Types
LocationLocation#All Locations
Device Porttty2
Remote Address192.168.41.73
Authorization Attributes
All Request Attribues
All Response Attribues
TACACS Protocol
Authentication MethodNone
Authentication Privilege Level0
Authentication TypeASCII
Authentication ServiceNone
Other Attributes
ConfigVersionId74
DestinationIPAddress192.168.40.73
DestinationPort49
UserNamenetadmin@gmail.com
ProtocolTacacs
RequestLatency24
TypeAuthorization
Service-Argumentshell
NetworkDeviceProfileIdb0699505-3150-4215-a80e-6753d45bf56c
AuthenticationIdentityStoreGuest Users
AuthenticationMethodLookup
SelectedAccessServiceDefault Device Admin
SelectedCommandSetPermitAll
IdentityGroupUser Identity Groups:GuestType_Contractor (default)
SelectedAuthenticationIdentityStoresGuest Users
AuthenticationStatusAuthenticationPassed
UserTypeGuestUser
CPMSessionID2429714507192.168.40.83361Authorization2429714507
IdentitySelectionMatchedRuleAuthentication Rule 1
Network Device ProfileCisco
IPSECIPSEC#Is IPSEC Device#No
Response{Author-Reply-Status=PassAdd; }
FAILED LOG
Overview
Request TypeAuthentication
StatusFail
Session KeyISE2673/356880508/132
Message TextFailed-Attempt: Authentication failed
Authentication PolicyNew Policy Set 1 >> Authentication Rule 1
Selected Authorization ProfileDeny All Shell Profile
Authentication Details
Generated Time2019-09-03 16:09:23.858000 +05:30
Logged Time2019-09-03 16:09:23.858
Epoch Time (sec)1567507163
ISE NodeISE2673
Failure Reason13036 Selected Shell Profile is DenyAccess
ResolutionCheck whether the Device Administration Authorization Policy rules are correct
Root CauseSelected Shell Profile fails for thsi request
Device Porttty2
TACACS Protocol
Authentication ActionLogin
Authentication Privilege Level1
Authentication ServiceLogin
Other Attributes
ConfigVersionId74
Device Port3358
DestinationPort49
ProtocolTacacs
RequestLatency121
TypeAuthentication
AuthenticationMethodPAP_ASCII
AuthorizationPolicyMatchedRuleDefault
UserTypeGuestUser
CPMSessionID925757830192.168.40.83358Authentication925757830
StepLatency8=2925
Response{AuthenticationResult=Passed; AuthorizationFailureReason=ShellProfileDenyAuthorization; Authen-Reply-Status=Fail; }
Attached logs for reference.
5 Replies 5
Arne Bier
Hi @melvillec
Did you get a resolution to this? It's an interesting use case for sure!
When you create a Guest Type (e..g Contractor) then you specify where to put the MAC address by specifying the Endpoint Identity Group. Do not confuse this with the User Identity Group (Group that is defined and can contain user accounts ... NOT Endpoints (MAC addresses))
This means, that guest accounts do not have a concept of a Guest Group. At best, you could check during Authentication, by looking up the Identity Source Sequence of "Guest Users", and then test whether the authenticating user is found during Authentication.
Hi Arnie,
Thanks for your reply.
I still haven't got any resolution to this.
You are absolutely right as mentioned below that the Guest user identity group will not contain guest endpoint mac addresses, but only users accounts which we manually need to create. I had figured that out after testing.
If there was some way that ISE could store the guest user accounts created by the sponsor in an internal group, my use case would have been resolved.
I did however create a rule matching the guest user name in the TACACS authorization policy and it worked, but this is not feasible as customer will be creating random users due to which we cant go and make changes in the policy every time he creates an user.
Melville
Depending on how complex your Policy Sets are, have you considered building a Policy Set that performs Authentication against the "Guest Users", and then for good measure, you could make that an Authorization Rule as well (just for extra assurance that you're authorizing for that specific reason).
Hi Arnie,
I was already using the Guest Users in the ISS.
Calling the Guest Users in the authorization policy will apply to all guest users and I will not be able to distinguish them as I need to create different policies for different tacacs users based on shell profiles and command sets.
Melville
@melvillec wrote:
Hi Arnie,
Melville
Althought not a supported store to TACACS, perhaps this will help looking at the way we did it with Guest?
https://community.cisco.com/t5/security-documents/ise-guest-access-prescriptive-deployment-guide/ta-p/3640475#toc-hId-2129827407
