ALGO 8188 ceiling speaker
MinhPhan92575
ALGO 8188 ceiling speaker is registered to CUCM 12.5. The ring feature is working fine, but the paging feature is not working. When I call the page number, it is busy and drop. Checked the syslog, I can see the call make to paging number but there is an error "audio stream disable". Anyone has the fix for this ?
Albert Mitchell
you put this message into the "Industrial Networking" community.
I can't see how your issue is related to what Cisco believes is Industrial.
what products are you using?  lets see if we can redirect you to the appropriate community if it is non-industrial
barrykaauamo
Thanks for the information keep sharing such informative post keep suggesting such post.
BayCare Patient Portal App
betexkorin
Based on the information provided, it seems that there may be an issue with the audio configuration of the ALGO 8188 ceiling speaker in relation to the paging feature. The error message "audio stream disable" suggests that the audio stream may not be properly enabled or configured for the paging feature.
To troubleshoot this issue, it may be helpful to check the audio settings of the ALGO 8188 speaker and ensure that they are properly configured for the paging feature. This may involve checking the speaker's codec settings, network settings, and other audio-related settings to ensure that they are properly configured.
It may also be helpful to check the configuration of the CUCM 12.5 server to ensure that the paging feature is properly enabled and configured. This may involve checking the server's network settings, audio codecs, and other related settings to ensure that they are properly configured for the ALGO 8188 speaker.
If these steps do not resolve the issue, it may be helpful to reach out to the manufacturer of the ALGO 8188 speaker for additional support or guidance on how to troubleshoot the issue. Alternatively, it may be helpful to reach out to a community or support group, such as Doubt Connect, for additional advice or assistance from peers who may have experience with similar issues.
Doubt Connect can be a valuable resource for individuals seeking answers or support for technical issues, as it provides a platform for connecting with peers who may have expertise or experience in a particular area. In this case, reaching out to a Doubt Connect community or support group focused on audio or networking may be particularly helpful for troubleshooting the issue with the ALGO 8188 speaker and paging feature.
