Cisco Industrial Switch PoE issue
rickyrome86
Having issues with the switch below detecting a PoE device and powering it. Device complies with the IEEE 802.3af/at standards, it works on a PoE injector. Its only drawing about 5.9 W. No configuration works, even if i set the draw manually.  See below for messages. A "poe status" shows the port as "invalid PD"
9 Informational 2018-09-13T19:40:36+00:00
PoE: Firmware upgrade started
10 Informational 2018-09-13T19:40:36+00:00
PoE: No Firmware upgrade needed
11 Informational 2018-09-13T19:41:00+00:00
PNP-AGENT: Aborting PnP Discovery due to presence of non default startup config
Albert Mitchell
does this PD work with other Cisco POE Capable PSE devices (such as IE-4000 or Cisco 9300)?
there's not enough information below to debug your issue.
