Cisco PIX DNS not working.
RadxD461
I am having an issue with a Cisco PIX firewall. Yes, I know I'm old school. Anyways, the workstations on the inside interface can reach the internet and do everything. However they cannot ping Google’s DNS server (8.8.8.8) (8.8.4.4) Or my default gateway (192.168.1.1) . I have no idea what the issue is as I never touched anything.The problem just started out of nowhere. Any advice would be much appreciated! Here is my running config:
PIX Version 7.2(2)
hostname RDXLFW01
domain-name radxd461labs.net
enable password w1We8ZR.yX6EPBDl encrypted
names
dns-guard
interface Ethernet0
 nameif outside
 security-level 0
 ip address 192.168.1.80 255.255.255.0
interface Ethernet1
 nameif inside
 security-level 100
 ip address 10.0.0.1 255.255.255.0
interface Ethernet2
 shutdown
 no nameif
 no security-level
 no ip address
passwd w1We8ZR.yX6EPBDl encrypted
banner motd Warning! This Firewall is property of RADX Labs! Any unauthorized access will be prosecuted to the full extent of the law! You have been warned.
ftp mode passive
dns domain-lookup outside
dns server-group DefaultDNS
 name-server 8.8.8.8
 name-server 8.8.4.4
access-list acl_out extended permit icmp any any
access-list acl-out extended permit tcp any interface outside eq www
pager lines 24
mtu outside 1500
mtu inside 1500
icmp unreachable rate-limit 1 burst-size 1
asdm image flash:/asdm-522.bin
no asdm history enable
arp timeout 14400
global (outside) 1 192.168.1.81-192.168.1.95 netmask 255.255.255.0
nat (inside) 1 0.0.0.0 0.0.0.0
static (inside,outside) tcp interface www 10.0.0.7 www netmask 255.255.255.255
access-group acl-out in interface outside
route outside 0.0.0.0 0.0.0.0 192.168.1.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
telnet 10.0.0.0 255.255.255.0 inside
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 10.0.0.2-10.0.0.254 inside
dhcpd enable inside
class-map inspection_default
 match default-inspection-traffic
policy-map type inspect dns preset_dns_map
 parameters
  message-length maximum 512
policy-map global_policy
 class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
service-policy global_policy global
prompt hostname context
Cryptochecksum:04088dc0dc1c7fb77a1bd8fd52de512b
: end
RDXLFW01#
balaji.bandi
based on the information - is the ping working before ?
since you have DNS confgured as google DNS if that is working your ping should work too.
is this ping only not working google IP or any other IP ?
what is the error you getting when you ping from PC and when you ping from PIX ?
i do not see this ACL used any where or am i missing something here ? to be honest fogot the command try below :
access-group acl_out in interface inside
or
access-group acl_out in interface outside
BB
9 Replies 9
balaji.bandi
or
BB
Yes, everything was working perfectly fine before. I was able to Ping Google and my default
gateway with no issues, until yesterday when this problem happened.
It seems that I can ping any IP addresses on the inside interface of the firewall but I cannot ping any outside IP addresses.
This is what happens whenever I ping from my PC:
Pinging google.com [142.250.114.101] with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 142.250.114.101:
    Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
And whenever I do the same thing from my PIX it gets through.
Clear conn
Clear xlate
This will solve issue
MHM
RDXLFW01# Clear conn
ERROR: % Invalid input detected at '^' marker.
RDXLFW01#
RDXLFW01# Clear xlate
RDXLFW01# conf t
RDXLFW01(config)# Clear conn
RDXLFW01(config)#
RDXLFW01(config)# Clear xlate
there is no conn command.
RDXLFW01# clear ?
aaa Clear AAA run time data
aaa-server Clear aaa-server statistics
access-list Clear counters for a specific access policy
arp Clear ARP statistics
asp Clear the current contents of selected memory in the
Accelerated Security Path
blocks Clear system buffers statistics
capture Clear packets in a particular capture
console-output Clear messages stored in buffer
counters Clear protocol stack counters
cpu Clear CPU stats
crashinfo Crash information
crypto Clear crypto operational data
dhcpd Clear dhcpd binding | statistics
dhcprelay Clear DHCP Relay Agent statistics
dns-hosts Clear DNS hosts information
failover Clear failover statistics
fragment Clear the IP reassembly queue and statistics
gc Clear garbage collection process statistics
igmp Clear multicast membership related information
interface Clear interface statistics
ip Clear IP IDS statistics, etc
ipsec Clear IPsec operational data
ipv6 Clear IPv6 operational data
isakmp Clear ISAKMP operational data
local-host Clear local host network information
logging Clear internal or ASDM logging buffer
memory Clear memory tools information
mfib Clear IP multicast forwarding information base
nat Clear NAT policy counters
ospf Clear OSPF information
pc Clear information about Xlate, conn and local-host maintained
on PC
pclu Clear PC logical update statistics
pim Clear PIM information
priority-queue Clear the priority-queue statistics counters
resource Clear system resources and usage
route Clear routes learned through dynamic routing protocols
service-policy Clear MPF service policy statistics
shun Clear all shun filters
snmp-server Clear snmp-server statistics.
startup-config Clear startup configuration parsing errors
sunrpc-server Clear active SUNRPC services
terminal Turn off syslogging or pagination for this terminal
traffic Clear traffic statistics
uauth Clear uauth
url-block Clear url-block statistics
url-cache Clear URL cache statistics
url-server Clear URL filter server statistics
vpn-sessiondb Clear Session Database operational data
wccp Reset wccp information
xlate Clear current translation information
Clear local-host
It same ad clear conn
MHM
The command worked. but it didn't fix my problem. Any other ideas?
that clarify that you have Internet access from PIX firewall - i need to refresh my memory of that commands its beend 20 years now.
10.0.0.1 so from PC you able to ping this IP correct ? what is the PC IP address
between PIX and PC do you any other device ?
can you post from PC  ipconfig /all
have you tried reboot PIX ?
BB
i tried this again and it worked. Thanks!
