I have 3 IR1101-K9s that are the first of these units I have ever worked on. I first tried using the USB console to connect via Putty, but screen is garbled with no input. Connection via Ethernet I did see the router pulled an IP address from our DHCP server, so I tried the WebUI interface. Getting the login page I entered the default username & password webui:cisco with no luck (I tried cisco:cisco and admin:cisco).
I have now tried on 2 different Windows 10 machines, both have previously connected using the USB console to devices in the past (IR809 I believe was last one). So I believe I have no driver issues (yes the SiL drivers are installed)
I have no issues using Putty & USB to Serial adapter to connect with older Cisco equipment like ASAs or switches. I am at a loss now on how I can get connected to configure these modems
Solved! Go to Solution.
Hello Trent,
For CLI, please use the Baud rate 115200 in your Putty session.
To login to Webui, Please use Username: webui and the Password: cisco
Hello Trent,
Thank you, setting the baud to 115200 resolved the issue
