IR1101 support for Guestshell and Python
Stephen Craven
I am unable to activate Guestshell on the IR1101 running 16.12.3 as the router complains about missing a tar file.
Is this supported? Do I have to download the tar file separately?
Thanks!
RogueTwo-RA1#sh run | i iox
iox
RogueTwo-RA1#guestshell enable
Interface will be selected if configured in app-hosting
Please wait for completion
% Error: The package file /guestshell/:guestshell.tar, does not exist
Mirko Grabel
Hi Stephen,
the guest shell is not supported on the IR1101.
It is an entirely different architecture compared to the IR8x9s.
However, we are working on creating similar functionality with the help of an IOx app.
We are currently looking for EFT customers for this.
Would you be interested in this?
Kind regards,
Mirko
8 Replies 8
Mirko Grabel
Hi Stephen,
Kind regards,
Mirko
Thank you for the information and the offer. Unfortunately our needs are more immediate.
Is there an update to this?  I saw a guestshell.17.06.01a.tar is now offered at software.cisco.com under the IR1101 17.06.01 release folder, but I can't figure out how to put it in the right place and get it to work.
dtsanders
Community Member
I had some success using
app-hosting install appid guestshell package <path to tar file>
taken from  https://www.cisco.com/c/en/us/td/docs/routers/access/1101/software/configuration/guide/b_IR1101config/m-1101-features-17-5-1.html
Emmanuel Tychon
First download guestshell tar file here: https://software.cisco.com/download/home/286319772/type/282046477/release/Bengaluru-17.6.1a
On IR1101 guestshell needs to be installed first using:
Then you can enable it with:
guestshell enable
I'm currently on Cupertino 17.09.03a, will this same .tar work on this version or will I need an updated Tar?
Yes @dave.m162 , while I have not tested this particular release, this should work.
