02-26-2023 01:53 AM
Hey,
Got a couple of questions:
1. I would like to know which devices can FMC manage. I've tried to understand it from the Data Sheets but it is still not clear for me. can FMC manage ASA-based devices? Can FMC manage ISA 3000 with ASA?
2. What is the difference between Cyber Vision to IND in context of managing OT networks? Is there a reason for me to buy both of them for the same project?
3. Can I find somewhere videos of cisco devices installation process? The data sheets are nice but it is still not as Seeing it visually.
02-26-2023 04:40 AM
FMC manages only Firepower devices, Like FTD (Aka Cisco secure Firewall running firepower) - SFR Modules in the ASA
Cyber vision and FMC have different products,. depends on the requirement you need to both.
you can find integration below :
3. Can I find somewhere videos of the cisco devices' installation process? - this is not clear what cisco devices.
have you tried youtube and cisco webinars for that device installation (not sure what device installation as mentioned above?)
02-26-2023 05:13 AM
1. FTD is a software image rather than a device. A device is not FTD but running ftd. So I did'nt understand clearly which devices can FMC Manage.
2. I asked about what is the difference between Cyber Vision to IND (Cisco Industrial Network Director), not about the difference/Integration of FMC with Cyber Vision
3. By Cisco devices I mainly refer to Firepower 2130, FMC 1600 apliance, IE-4010 switches, ISA 3000 firewalls. I tried Youtube, but where are cisco webinars?
02-26-2023 09:33 AM
cisco changes names very often - hope you answered your question yourself here.
May I was not clear so hence the guidance before posting?
May be below URL help you :
FMC :
https://www.youtube.com/watch?v=8Y2Zw2wh62k
Industrial-related admin guide or below resource help you :
02-28-2023 08:59 AM - edited 02-28-2023 09:03 AM
@zohar7471 - it looks like you asked this question a second time so cross-posting in case others have similar questions regarding the differences between CV and IND - https://community.cisco.com/t5/industrial-networking/cyber-vision-anomalies/td-p/4783758
In terms of the question regarding purchasing both, The use cases for each product are different. IND is more focused on providing simple network monitoring where as Cyber Vision is focused on Industrial Asset Visibility, Vulnerability Identification and Operational insights.
