FTD enabling SFP interface
Alen.
Visitor
Hello guys.
I'm having problems with my Cisco FTD 2140, at the moment of enabling the interfaces with SFP module.
In the image below can see that when I enable the interface, it sends me that message.
I'm using the interface Ethernet 1/13 with a SFP module.
My appliance is a FTD 2140, version 6.6.5 in HA deployment.
Please, If anyone else had a similar (or the same) issue that Could give me some advice on how to address the issue?
yumewang
Hello @Alen.
Based on your screenshot and the problem description, you might be hit with this bug.
Could you please try the workaround and see if it solves the problem?
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvq01485
You can also learn more about Secure Firewall (formerly known as NGFW) through our live Ask the Experts (ATXs) session. Check out Cisco Network Security ATXs Resources [https://community.cisco.com/t5/security-knowledge-base/cisco-network-security-ask-the-experts-resources/ta-p/4416493] to view the latest schedule for upcoming sessions, as well as the useful references, e.g. online guides, FAQs.
Are you trying to install a 10G SFP or 1G? 10G SFPs are not supported on the 2100 FTDs. However, if you are trying to install a 1G SFP, could you please share the interface hardware settings for review? Also, you can connect to fxos and show the interfaces details including port channels as follows:
- connect fxos
- scope eth-uplink
- show detail expand
Alternatively, if you only want to list the interfaces that are not part of the port channel then you can do this:
- connect fxos
- scope eth-uplink
- scope fabric a
- show interface expand detail
FP 2130 and 2140 does support 10G SFP+ modules.
