2007 Deployer- migrating an auto-cose agent
Mary Schlemmer
Is anyone else having an issue using Catalog Deployer to migrate an auto-clsoe agent (the workflow type of a service in the Plan tab)? We having troubles migrating that from teh Dev environemtn to Test.
CatalogDeployer doesn't migrate agents. It's a known omission. You need to manually create the agent in the target site. Please enter an enhancement request to get this capability.
Ye Ye
Does CatalogDeployer migrate adapters?
No. If it's a standard adapter and you made some changes to its properties (possible but not usually recommended), you would need to re-enter the properties in the target environment.  If it's a custom adapter, use the same procedure you used to install the adapter in the initial environment in the target environment.
