Best practice for maintaining URLs between Dev, Test, Production servers
amodt.ivan
We sometimes send order confirmations which include links to other services in requestcenter.
For example, we might use the link <href="http://#Site.URL#/myservices/navigate.do?query=orderform&sid=54>Also see these services</a>
However, the service ID (sid=54) changes between our dev, test, and production environments.  Thus we need to manually go through notifications when we deploy between servers.
Any best practices out there?
mike_jones
Your best practice in this instance depends a bit on how much work you want to put into it at the front end and how tied to the idea of a direct link to a service you are.
If your team uses a decent build sheet and migration checklist then updating the various URL’s can just be part of the process. This is cumbersome but it’s the least “technical” solution if you want to continue using direct links.
A more technical solution would be to replace your direct links with links to a “broker page”. It’s relatively simple to create an asp page that can accept the name of the service as a parameter and then execute an SQL query against the DB to return the ServiceID, construct the appropriate link and pass the user through.
A less precise, but typically viable, option would be to use links that take advantage of the built in search query functionality. Your link might display more results than just one service but you can typically tailor your search query to narrow it down. For example:
If you have a service called Order New Laptop or Desktop and you want to provide a link that will get the user to that service you could use: http://#Site.URL#/RequestCenter/myservices/navigate.do?query=searchresult&&searchPattern=Order%20New%20Desktop%20or%20Laptop
The above would open the site and present the same results as if the user searched for “Order New Desktop or Laptop” manually. It’s not as exact as providing a direct link but it’s quick to implement, requires no special technical expertise and would be “environment agnostic”.
mike_jones
amodt.ivan
The asp and searchpattern urls are a good workaround... appreciate your help Michael!
