Can NETCONF be parsed by JSON?
louis25448
Can NETCONF data be parsed by JSON? I've heard RESTCONF can be parsed by JSON or XML, however NETCONF can only be parsed by XML.
Is this true?
Thanks!
AJ Cruz
Level 3
Level 3
NETCONF uses XML for encoding.
I'm not aware of an option on cisco platforms to tell NETCONF to accept or produce JSON-encoded payloads.
That being said you can easily convert XML to JSON. If you're using Python the json & xmltodict libraries will help you.
Netconf uses only XML encoding. But if you need to manipulate the XML payload in JSON you can do it over a python script if you went.
