CIAC 4.0 Install manual, problems with the procedure
Alejandro Madurga Ainoza
Hi all,
I´m trying to install the latest CIAC version, and I´m facing some problems on the configuration phase.
I´m using the following document:
Cisco_Intelligent_Automation_for_Cloud_4.0_Installation_Guide.pdf
Dowloaded from the Cisco portal.
In the page 34 we can found the procedure to install the REX adapter.
The procedure is very confusing, and I´m not able to find where to put the REXAdapter.xml, it points to C:\Rex\Deploy, but the CIAC appliance is based on linux, and I´m not able to find that file on the Portal Server.
Also the adk.zip is missing from CPO Automation packs.
Thanks in advance,
Alex.
rvadlapa
The 4.0 appliance already has the RexAdapter installed. You can look in the Service Link Adapters list.
rvadlapa
Correct, the appliance runs a Linux operating system and comes with the REX adapter preinstalled.
Thanks for the info, seems the documentation needs a detailed review, I´m a newbey on CIAC and it really confusing.
Thanks all for the help.
Alex.
