CIAC Cloud tap VMware Keystore Password Panel
mimahon
I am on the screen for the import wizard for Cloud Automation and I get to the part where it asks for the keystore password.  Here is the help text:
Use the Keystore tab to enter the password that protects the Java keystore file used to keep SSL certificates for all configured VMware targets.
For new installations, this password can be set to any valid six-character keytool password. For installation upgrades, this password can be set to the password that is already used to protect the previously configured keystore file.
Field
Description
Keystore password
Enter the key file password which provides access to the file.
Note: The Required Value  icon displayed on a tab or page indicates that a required field is missing a value.
How do I get this keystore password for existing VMWare targets?
Any help is greatly appreciated.
Thank,
Mike
You generate this password yourself.  Just type something in. It's used to get access to the keyfile itself.  The required keys from vCenter are already in there.
mimahon
Does it need to be from the ESX Server or is it something I generate myself?  Is it the public or the private key?
