Copy an AFC
Hi.
Does anyone know a way to copy an AFC?
It´s so tedious to create a new AFC which is 99% the same as another one. Especially creating some 40 or 50 rules again...
/Jonas
mpetra
The easiest way - is the create a catalog deployer package containing the service and AFC.
Create the package ( transport service or your existing service).
Rename the existing AFC to the newly desired name.
Export the package xml
Delete the transported package.
Import and Deploy the package xml
The import will add a new AFC since it did not match by name.
