Data model of CIAC 3.1 vs vCloud
lruelle
I search for a data model info, shema,  about CIAC 3.1.
What is the model of CIAC 3.1 compraring vCloud ?
Could I use the VDC object for another level (vApp) and which network is plug where ?
Thank in advance for your reponses
lruelle
So in CIAC 3.1 there is no MCAK.
We could tried to import a part a MCAK 3.11 to add some object like vApp.
It's not a good idea to use VDC for other things !
There is no doc/pdf to describe the data model of CIAC 3.1 or the MCAK add-on.
We move now to CIAC 3.11
Correct. MCAK is for 3.1.1.
It does support vCloud, but uses the IAC 3.1 Cloud Model, so although it creates a vApp, there is always 1:1 vApp:VM.
We would love to have someone extend the Multi-Cloud content to have 1:m vApp:VM. All the pieces are there; they just need to be assembled as part of IAC w/MC. (PS. We are working on another project to extend the cloud model to cover PaaS use cases with server stacks, which makes the need for vApps go away).
