Delete Selected Records? Please Enter Configured Passcode.
Tim Lazarus
Has anyone seen this message before? Trying to delete a job, and getting prompted to enter a passcode. I've inherited this system, and I have no idea why (or how) a passcode would be used to protect a particular job. Additionally, if this is supported, does anyone know where it is documented? I can't find any information about it in the user guide.
Tim
Prakash Hemchand
Hi Tim,
In the SYSVAL table for the tidal schema, see if you have any entry for SYSVAL_ID=123.  Then see if it works as the password.  You can't protect a single job AFAIK but you can protect a group of jobs.
Prakash Hemchand
Hi Tim,
Worked perfectly - thanks!
