EEM for N9k
cypherscuall
Is there any way to prevent using EEM a command from taking place using N9k, let say that I want to prevent changes on the interface Eth1/1, something like this should work:
event manager applet test
 description "do not modify Eth1/1"
 event cli match "interface Eth1/1"
Is there anything else I have to add. There was a skip in IOS but I dont find that option in NXOS.
Thanks.
Rick1776
Level 5
Level 5
I don't believe this is possible with EEM. Events only allow you to see if certain action has taken place. You could monitor the event via an action and receive an email when that interface has changed. You may also want to look at using TACACS+ that can give users those granular controls per device.
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus9000/sw/7-x/system_management/configuration/guide/b_Cisco_Nexus_9000_Series_NX-OS_System_Management_Configuration_Guide_7x/b_Cisco_Nexus_9000_Series_NX-OS_System_Management_Configuration_...
