Enabling Site authorization
pnisha
Using Site authorisation ,I cant to create departmental authorization and departmental reviews. Add option is disabled. Is there any procedure to enable the add option.
Mark Swanborough
Hi Parvin,
I think you mean the option is disabled at the Service level?
To enable it, it must first be enabled for the entire site. This can be found in "Site Administration > Authorisations" (http://example.com/RequestCenter/administration/adminnavigate.do?query=authorizationconfig&resetBN=true&tabId=8521)
Then Edit the Departmental level.
Hope that was it?
Mark
I enabled site authorisation. But cant edit Departmental levels.
