Showing results forĀ
Search instead forĀ
Did you mean:Ā
ADMIRAL database on SQL 2008 R2 Named Instance
KRYS-group
we are running  TES 6.1.0.133 (test Master) upon a remote SQL 2005 SP4 named instance database, all is right.
I need to move the ADMIRAL database to an SQL 2008 R2 SP1 named instance.
What JDBC, JRE and connection string do I need to succeed ?
The versions are JRE 1.6.0.30, Microsoft JDBC 4.0.
thank in advance you for your experience,
Frederic
0 Replies 0
