Bookmark
Subscribe
2894
Error[#267] Creating Process for job 5853305
recently we are getting this error:
when we re-run the job it works. sometimes re-run does not work sometimes it works. please advise what is the error related to and how do we fix it. thank you.
Derrick Au
Level 4
Level 4
Hi Warren,
Error [####] is a Windows error code and a quick lookup from
https://msdn.microsoft.com/en-us/library/windows/desktop/ms681382%28v=vs.85%29.aspx
shows that the directory is invalid
Interestingly, a re-run would work? I am curious as to what directory you are referencing and how?
BR,
Derrick Au
Derrick Au
Level 4
Level 4
Hi Warren,
BR,
Derrick Au
yes it was an error thrown by the powershell. i was thinking maybe a network hiccup occurred or a restart of the agent might solved that issue.
