Error : <Target Name> unreachable
swaupadh
Hi, I am trying to run a powershell script, for which I have created a windows target pointing to the same host where CPO is running. Still we are getting error "target unreachable". Not able to figure out what could be the issue. Thanks, Swati
Tuan Tran
Swati,
Can you send me the log files?  If possible, export the process to a TAP file and send me the TAP file as well.
-Tuan
