Getting an error to order a VM for Linux using a Template
ynoor
Hi All,
I have tried to submit the order  a VM for Linux RHEL6.1.
Portal page is not showing the Administrator Password's   "Enter and Renter" tabs on the page and the message showing on the the tab space is as follows:
Important: To set the root password on  your virtual machine, please refer to the appropriate restrictions for your  Linux operating system flavor.
I have created root password on the RHEL OS itself
I submitted the order after that it is showing the error as follows:
Can any one help me on this how isolate this issue..?
Thank in Advance.
-Noor.
mpavlish
Unfortunately there is not enough information here. It is possible that some of the configuration steps have not completed successfully. Without seeing adding screenshots or XMLs it might be hard to answer this question.
Could you please open TAC case? They woudl be able to answer it quickly.
Also, is this question about Cloud Solution or Workplace Solution?
Max.
