How to Configure approval
florentd2si
I want to configure approvals on a service only for VSO. So I add an approval in Authorizations tab and I put this on the condition field:
"Approval"="Approval" and "SIBDApprovals.OTAApproval"="Yes".
I checked that the value of OTAApproval is "Yes" when the user is a VSO and "No" if an OTA order this service.
But it doesn't work. There is no approval. If I only use "Approval"="Approval" as a condition, there is an approval for all user who order this service.
So how to configure Approval for VSO and not for OTA?
meisenst
Level 4
Level 4
Do you have actual quotation marks around SIBDApprovals.OTAApproval in your condition statement?
You shouldn't have quotes there.
I have the quotation marks.
If I remove them, when validate I obtain:
Expression "Approval"="Approval" and SIBDApprovals.OTAApproval="Yes"
  Validation Result:unexpected token: SIBDApprovals.OTAApproval
Lee Calcote
Level 3
Level 3
You'll want to start with configuring approval for this service via the Configure Approvals service.
And then extend the service with an additional conditional for VSO users only.
