How to pass input from parent process to child process as a XML.
msivarami3
Hi I need to pass xml as a input to my child process .can any one help me on how to construct a xml and pass it to child process.
sivaram.
Shaun Roberts
Create an input variable that is a multi-line string and then insert it into the child process when you pass it. As far as contructing the actual XML, that's up to you and dependent on the situation/what your XML needs to do or what payload it contains.
--Shaun Roberts
Principal Engineer, CX
shaurobe@cisco.com
