Create an input variable that is a multi-line string and then insert it into the child process when you pass it. As far as contructing the actual XML, that's up to you and dependent on the situation/what your XML needs to do or what payload it contains.
--Shaun Roberts
Principal Engineer, CX
shaurobe@cisco.com
