How to submit a job into a job group
Using  job events/actions we occasionally need for a scheduled job to submit another job into the current schedule.
The issue here is that the submitted jobs go straight into the highest level view.  We will need to do this for over 400
times in one night, and do not wish to flood the operators view, so are simply trying to find a way to submit it so that
it shows up within an already existing group.  Any ideas?
Michael Durette
It’s just a thought…… but you could..
Job Group A
                Jobaa- run
                Jobab – echo a blank file to a shared directory, example: /C "echo ''> \\USNPKETLP03\Infa_Shared\File_Inbound\zcmtyr_eu.csv
Job Group B
                Jobba – run dependent on zcmtyr_eu.csv being present. Use the check box, “rerun each time the dependencies are met”
                Jobbb – delete the echo file.
