How to use FOR loop in CPO
esramasa
Hi All,
I want to use FOR each loop in CPO.
What is the syntax to use FOR each loop and how to capture outputs from FOR loop.
Like in what scenario we can use FOR each loop.
Shaun Roberts
For each is to loop through a table. So in basic code it is
for-each "row in table X" do:
  //code here
You should use this when you need to iterate through a table of things and do something with each piece of data in that table.
--Shaun Roberts
Principal Engineer, CX
shaurobe@cisco.com
