How to use wildcards in REST filter for subscription items
devmandan
I am following this documentation:
String column filters
Support % (starts with) operator.
Support * (Contains) operator.
Does not support (ends with) operator.
Examples:
Name=service*
Name=*g*
Name=*g -- not allowed
REST URL:
http://<ServerURL>/RequestCenter/nsapi/serviceitems/serviceitemsubscription/<columnName>=<wildcardValue>
I can get filters to work without wildcards, but have had no success using '*' or '%' characters.  Please provide a properly encoded sample URL for
ServiceItemTypeName starting with 'Virtual'.  I have not been able to get any data returned when using wildcards in a filter.
Here is what I have tried:
ServiceItemTypeName=Virtual Server Snapshot
http://10.8.0.46:8080/RequestCenter/nsapi/serviceitems/serviceitemsubscription/ServiceItemTypeName=Virtual%20Server%20Snapshot
response: 200
<?xml version="1.0" encoding="UTF-8" standalone="yes"?><AllServiceItems totalCount="1" recordSize="1" startRow="1">
literal works as expected
http://10.8.0.46:8080/RequestCenter/nsapi/serviceitems/serviceitemsubscription/ServiceItemTypeName=Virtual%25
Application-Type=application/xml
response: 200
<?xml version="1.0" encoding="UTF-8" standalone="yes"?><AllServiceItems totalCount="0" recordSize="0" startRow="1"/>
expected result not returned
ServiceItemTypeName=Virtual*
http://10.8.0.46:8080/RequestCenter/nsapi/serviceitems/serviceitemsubscription/ServiceItemTypeName=Virtual*
500
<nsapi-error-response>Internal Error: Invalid parameter values specified or unexpected error.</nsapi-error-response>
fails with error response
Mark Swanborough
Hi Dan,
I don't think you can use wild cards here.
Please see the Integration Guide for 9.4. Section: "REST API -> Quick Reference".
Here you'll find a table of what features are supported for the different resources exposed by the API. In there you will find a row for "All Service Items", and you'll see that: Get All, Sorting, Paging and All Filters are supported; Wildcards Name Search are not...
When I came accross this same situation, I assumed that I am trying to do a Wildcard Name Search here... and it's not supported. It does, however, work for the other (SI Designer created) columns, which is what I believe the documentation is trying to describe. (Though, personally, I feel this is a bug).
Mark Swanborough
Hi Dan,
