Is CPO's max iteration count configurable?
Michael Whiteley
We're getting the following in a runaway loop during testing of a workflow "A violation of the maximum iteration count within activity While ProcessRunning. The maximum allowed number of loop iterations is 5000."
Is 5000 alterable? It would be nice to configure a lower limit
Thank you
Mike Whiteley
Yes, it is configurable.
If you want to lower it, you can modify the following in the Tidal.Automation.Server.exe.config file.
        name="MaxLoopIterations"
        serializeAs="String">
        5000
I do not recommend setting it higher.
For anybody who hits this limit, please examine your process and see if it could be redesigned without so many iterations.
        5000
Thank you
/Mike
