Keep adding a day to a static date.
Michael Durette
Hello....
I'm looking to do the following:
01/01/2013
+1
01/02/2013
+1
01/03/2013
and so on to 05/16/2013
So the job I'm running will repeat 135 times.
I've tried calculate date, but all I get is 01/01/2013 to 01/02/2013.
That you for this help....
We are running 5.3.1.374 Tidal
Even if I need to run a unix script and fill a variable that will be fine.
Michael Durette
I was WAY over thinking this issue. Kind of.
The date format was 20130101 and I needed to 1and increment by 1.
I created a variable to do a +1 then I would run the job 30 or 31 times depending on how many days in the month.
Then I would manually change the variable to 20130201 and run the next month. It is still a manual process 12 times, but at least we didn't do it for every day.
Thank you to the 26 who have viewed this post.
Resolved.
Mike
