move reports from 2006 to 2007_1
Charles Haynes
Is there a quick way (not through servicemigration) to move email templates from RC 2006 to RC 2007_1 without copy/paste one at a time?
thanks
cmh
Charles Haynes
I did mean email templates.  I guess I should have posted this one in the Site Admin. section.
Problem solved.
I exported the service from 2006 and imported it into 2007.  I discovered the emails are apart of the xml extract.
thanks for your help
cmh
Song Bac Toh
Do you need to move email templates or reports?
If you meant reports, are these reports that you have created using Report Studio or Query Studio?
There are different ways to move reports.  If you have only a handful, copy and paste works better.  If you have a large number of reports, then export and import from the reporting home page is more appropriate.
If you can provide more information on what you need, I can provide more detail.
Thanks.
Song
Emir AmEx (9.1)
you can use serviceMigrate and extract and deploy the email templates only
