SQL Server Database Target Update Problem
Kyle Foo
Community Member
Hello all,
I am trying to update a SQL Target using CPO Northbound Web Service, however, I do not find any service available to do that. What are the alternatives to achieve the Updating of SQL Server Target? Best to avoid doing it manually on the Target Properties, webservice call will be my desired approach, any advise?
Thanks.
meisenst
Level 9
Level 9
This was a late removal from 2.3 due to issues in related areas that were also cut late.  The SQL target web service methods will be restored in PO 3.0.
What's the use case for which you need programmatic SQL Server target updates?
Thank you Michael for the reply. I was trying to automate the Target update based on certain input so that corresponding SQL Server will be addressed correctly. Well, I think I will have to opt for another approach. Thanks again.
