Tables and Column Info to know the Different Types of Job
I am trying to look for tables and column names that will give me what are the types of job. for example i need to do a query on all jobs that are FTP job, command jobs, oracle jobs, etc. i saw there is a column jobmst_type on table tidal.jobmst and i would like to know what does each of the value correspond to? if there is any lookup table to cross reference those values. please advise.
thank you,
warren
2 Accepted Solutions
Try right clicking and choose properties.  Do you see unblock as a choice?  If so then click that.
Sometimes unregistered HTML Help viewer component can also causes this problem, try to register it by running command in command prompt “regsvr32 hhctrl.ocx”.
8 Replies 8
Robert Gardner
Hi Warren
The scheduler Data Model is a windows compiled help file that describes the structure of each table and in particular to this question your starting point will be the jobmst table.  FTP jobs are listed with a value of 6 in the jobmst_type field.
Attached is a zip file containing the data model for tes 5.3.1
This should get you going.
Bob
i unzipped and when i opened it does not work. please advise. thanks.
Hi Warren,
Verify the file ends with a .chm extension, and then try saving it to your desktop.
BR,
Derrick Au
hi derrick,
yes it ends with .chm and i saved it in my desktop. still not work. i am using windows 7 64 bit version.
thanks,
warren
it is working now i clicked on the file properties unblock. thanks so much.
that works i clicked on the unblock button. thanks so much.
